home limit replaced ,cables checked moves up fine will not move down , x & y home out then z moves up , shows warning " z axis need home " , used machine gifted to me , i am retired cnc machinist , have 3 lasers and 1 4x4 ft engraver and a 4x4 plasma tables , new to 3d printer , not cnc , this is why friend gave to me , there is all type of fixes on google search ? ( 1 was new home limit switch ) looking for someone who knows a fix , thank you
well , i will try to google again , seems like after 2 days ,someone would know ?
Unfortunately I am afraid you will find that help on this forum is pretty slow. I am a retired CNC tech. Since you have already replaced the home switch and that didn’t help there are a couple of other things you can look at. You said it homes x and y and then Z moves up. Z should move down, not up after x and y are homed. My Ender 3 pro has been modified with a new controller and firmware so I can’t give you specific instructions. But either in the software or maybe a switch on your drive board there should be a way to change the direction of the z axis. If you can manually tell Z to move, see if it moves in the direction you tell it to. I’ll try to remember to check this forum more often to see if I can help you any further.
I had a similar problem when setting my old Ender 3. I had a Bltouch fitted with the switch contacts in the Z limit socket on the control board. I found that I had an open circuit on the switch wiring, ( brocken wire). Worked OK when wire was repaired.
Bill
