Never owned a 3D printer and I recently purchased a used Ender 3 S1. Had some tip heating issues and thought an update might fix to find out I installed wrong software. I removed bottom cover after I already screwed up to see chip set was FDM-V24S1_301. On Creality firmware, its the last one on page, I think. ( Mainboard Version: V24S1_301 25 Mar. 2022) Only thing is, they do not have release notes or install instructions. I tried to update both mainboard and screen. No idea how to fix issue and being I only had this thing 3 days now and screwed it up, I’m quite frustrated and ready to trash this thing and buy a new one. Any help would be awesome. Its the CRtouch version.
It looks like the firmware you will need is indeed the bottom one on the firmware downloads page (Mainboard Version: V24S1_301). To install the firmware you need to do the following…
Update Mainboard:
Format the SD card as FAT32 with 4096 allocation.
Rename the Ender-3s1-hw24s1_301-sw-V1.0.5_C-CRTouch.bin file to firmware.bin and place it on the SD card.
Insert the SD card into the printer and power on, allow the update to complete.
Once complete power off and remove the SD card.
Update Screen:
Place the DWIN_SET and private folders onto the SD card.
Insert the SD card into the card slot in the back of the screen. (you may need to remove the screen cover to access it).
Power on the printer and allow it to perform the update.
Once complete power off the printer and remove the SD card.
Thank you for your help. Screen update worked but no luck with mainboard. I downloaded firmware, opened file folder, copied bin file to sd card, renamed, (this was only way I got option to rename) inserted, and powered on. Still have logo with random numbers on screen.
Just wanted to update that I was having similar issues, but it was due to firmware miss match. I had attempted to use Professional Firmware which was not compatible with my control board. I attempted to revert using the current firmware, but it was not compatible with my screens version so it just displayed some numbers at the bottom of the screen (temps, speeds etc.) I was able to download previous version of the motherboards’ firmware from Ender Series Firmware Download | Creality 3D Printer Firmwares and that worked like a charm. (just slap it in STM32F4_UPDATE folder, pop that sucker in, bob’s your uncle)
