Ender-3 S1 (not Pro), Filament not extruding
I was printing great when the Ender decided to keep running but not extrude any filament. It’s like it was printing on air. I assumed it was a clog and disassembled the entire unit to clean it, but it was clean inside. I replaced the nozzle anyways. Still no filament. It appeared the motor to extrude was not turning (I placed a small mark on it with a Sharpie), so next I assumed the motor was bad. I purchased a new Sprite Extruder and installed it. Same issue. I tried a new roll of Creality PLA as well. I can manually push it through when heated, but it won’t print, even with a new extruder, hot end, and nozzle. I’m beginning to think it’s the daughter board as I have tested all the cables. I’m almost to the point I don’t want to throw more money at it. Thanks for any help or ideas.
Had the same issue with my old s1 pro. Turned out to be the ribbon cable was faulty due mainly too the continue flexing. Replaced the cable and all worked OK.
Bill
I am experiencing the same issue, but mine will work for a while before the extruder quits.
My S1 pro was intermittent also. Would print for any were between 2 to 40 layers before failing.
Bill
I have had similar Issues, for me it was the Extruder-Motor - one of the Coil-Cables was broken.
The Extruder stopped while printing with some Vibration by loose contact.
I bought a new Extruder for the Ender 3 S1 - all fine now.
I hope it helping . . . .
Cheers
Elmar
