Hello i recently posted that i had an issue with my printer i thought i had fixed it but the firmware installed will not allow me to print, would anyone happen to have a firmware copy for the Mainboard Skew CR4N5200141c13.
Hi,
I have the good firmware that works with the 401 chip:
Ender-3S1_Pro_HWv24S1_301_SWV2.0.8.28F4_F401_FDM_LASER
Thank you that worked, i also made sure to install the lcd’s firmware first and got it running, only issue was the extruder didnt work, i bought another mainboard and it worked so i might have fried something installing the firmware from the sonic pad or installing the wrong firmware, when i originally setup the Sonic pad i tried to setup through usb-c, second time i setup the sonic pad with the serial connection and follows the on screen steps which worked flawlessly, keep that in mind if your installing a sonic pad on a new s1 pro printer with a CR4N5200414c13 Mainboard
