Ender 3 S1 Pro using Sonic Pad no longer works in Creality Print V6
Lost the use of my Ender 3 S1 Pro connected to my sonic Pad was working fine in V5.1
But will not find printer or Sonic Pad in V6
Can’t find my Ender 5 plus which is connected to a Sonic Pad, but then again the 5+ isn’t listed.
just updated to V6 today… the sonic pad is no longer listed as a device… hopefully this will get patched
Tried the IP address that shows up in Orca just reports no such device in V6
Same issue here
Same for me
just installed latest version which says it will fix this, but still cant add a sonic pad as a device… added as other device via wired ip address and i can view the printer info temps etc. but when you press print it does not allow you to select the printer
Experiencing this myself! Also just did the update to 6.0.1.XXXX and still no joy. Worked (and works) still in my 5.1.
Same exact problem
For the past two years, I only use Cura for my sonic pad connected an Ender 3 S1 Pro with - no problems. I tested with creality print 5.1 and 6 with no results. I use creality print 6 for my K1c with no problems.
Bill
I have the same issue. No way to find the sonic pad ( with a E3 S1plus connected ).
Anyone have found how solve this problem?
Yes use Orca, you can find it straight away on there.
Hello, I have the same problem with Ender 3 S1 Pro + Sonic Pad and v6 of the Creality Print.
I can not find the printer to print.
That, right there, is MOST likely your problem.
Also getting the same problem. As others have stated, v5 was fine, v6 no go
Scan manual, add device, other, enter the IP address (I have multiple printers checked) and it has added the printer, why did it take me so long?
Hello Bonfireman,
Do you mean to say, "You have version 6 working ok for you now " ?.
Cheers.
I have v6 working, not sure how OK it is so yes I can access the V3SE and Ender 5 plus. I can also locate my V3KE but can’t access the camera:-
*Creality Print camera function does not currently support devices that are only bound to Creality Cloud
Not sure what that means.
Ok only half works, very sketchy. Back to Orca.
hi Same issue here, V5 and V6 cant find the printer attach to the sonic Pad… Smart-10 pro in my case. and its not listed in the list of native printer… these things are not old I wonder why they are not in the list…
starting to annoy me a lot…
Yea works fine with my New K2 Plus but want them to sort it for my Sonic Pad and Ender 3 Pro
Why do they not fix things for their own products, no wonder buyers go elsewhere…
