Ender 3 S1 pro z newbie offset issue
Ok, new to the forums. Been printing as a hobby (5-10 prints a year) for a couple of years. Just started trying to get more active.
Everything was going fine for my first 4 prints after trying again, then it all went to hell.
In the middle of a 5 hour print (I stepped away because I can’t watch it that long), 3 of the 4 leveling knobs loosened and fell off. the print went to crap so I stopped it.
I tried to relevel the bed and put everything back together to try again. It wouldn’t work. Leveling the bed with the screws isn’t working and the z-offset is maxed down at -5. My initial layer refuses to stick, and it is stringy and unattached.
Is there a way to RAISE the bed? Even with all of the screws completely loose I cannot get a smooth initial layer and the bed isn’t level.
Any assistance appreciated.
Hi,
I have also been using an Ender 3 S1 Pro for a few years now. The only levelling problem I had was when the print head refused to travel down to closer than 20mm from the bed. A new probe fixed that.
You say that the adjustment wheels came off during printing? The only way I can see that happening is if the wheels are catching on something to unscrew them while the bed is travelling, or if they were already unstable at the end of the thread.
For sure you should not have the screws completely loose. Can you not screw them back on to approx half their total adjustment depth and then try auto levelling.? If not, why? If you can, then if the print head cannot be lowered to the bed after auto levelling then perhaps you should try replacing the auto leveller probe.
Regards
