Ender 3 V2 Neo, Autohome x axis no move
Hello, newbie here, I just set this up and cant find a video to fix the autohome x axis. The print head moves up slightly then attempts and fails to move left on the x axis with a bad “grind” noise and the print head shaking.
This sounds like the belt slipping or jamming, causing the stepper to make a noise.
With the power turned off, can you move the hot-end assembly by hand across the gantry (X-Axis)?
Fixed.
Yes, it does with the power off.
Upon further inspection, one of the X axis motor wires was loose inside of the connector, couldn’t see it until I attempted the x & y wire swap that some others have had success with.
Had to make sure all four wires were engaged inside the connector, now onto printing!
Hello circa79,
Good news to hear.
Happy printing.
Cheers.
