I noticed that on the right bottom side of my bed, there are 4 screws which are very very low. I saw a little “scratch” on the screen and tried to clean it off, then I realized that the front two screws had destroyed and taken off a small chunk of the top part of the screen. Not the screen where you touch, but the gray frame around it. I am very worried, is there a fix for this?
Are the threads sticking out? Could use slightly shorter screws or file yours down. Is the screen mounted on slots? Can you push it further down and away from the screws? Bent bed perhaps?
Let me check, I’m pretty sure the screen is pushed down enough.
