Ender 3 V3 CoreXZ Control of light bar
Creality suggests connecting light bar to power strip. I noticed that the CoreXZ board has a connector labeled LED. Anyone know if this source would power the LED light bar and allow control from Creality Print? Thanks
I wonder if that is for the LED on the extruder for the Creality label that lights up…
I’m guessing they suggested a separate power strip is that the machine has just enough power (350 Watts) for itself.
Any extra lines tapping off the power supply could cause an issue…
Sorry, I wasn’t clear. The auxiliary LED light is powered from the 24v contacts on the power distribution strip inside the printer. However while there, I noticed that the motherboard, has a connector port that is labeled “LED”. I haven’t found any reference to this in creality documentation. I was asking if anyone knows if that port might be for a LED light that could be controlled on/off from the device control within the slicer. I’m hoping for someone with specific knowledge of this board or has tried it and has first hand knowledge.
Indeed. A word of caution for ANYONE looking for making mods of your wonderful toy…
I carbonized the power terminals on my V2’s original Mainboard with the quest I’ve set myself upon for 3D printing. There’s not a lot of margins for anything other than the power ratings of the devices they picked there.
The bed heater will be the dominant one. Once I get back to trying to build out my V2 to be almost as stock tricked out as the V3’s I’ll be adding an AC powered bed heater/bed to the machine and controlling it from the power feed for the factory bed heater so that when I drive the HF or the HTF REVO cores from H3D, at 60 watts the poor steppers won’t have a stroke (Brownout) causing evil bad layer shifts.
There are no margins in the system directly. You want to drive external power supplies as cleanly as you can here.
You probably won’t get much for this model…YET… Too new.
You’re kind of in a similar boat to me. I want to print something…well…insane…and the V3 can actually step up to the plate to print it fairly reliably in an enclosure better than their Zipper-bag one…so long as you have a bed temp of 120 or better. I swapped out the stock bed heater and my Revo CR stock core for a High-flow 60W core. Some 100W beyond the original design. It…sort-of…worked… I was being lazy and didn’t really design the mods. Just bought stuff off Amazon and bolted it right on.
You will NOT be using the silicone peel-n-stick on 24v heaters on any Enders as a stock item. They exceed the design by about 60-70W of power. The 60w heater core pushes it really to the limit of the rating of the PSW…but under the right conditions, you will brown-out printing anything but the usual suspects. It’ll let you print PLA, PETG, ABS, ASA…but you will have off-and-on pain with Nylon and Polycarbonate…
