Hi all,
The first layer go’s pretty well, but only when I print from the centre to the rear right-hand side.
I could, of course, adjust the print bed by replacing the fixed spacers with rubber ones, or sand down parts until the bed is flat enough, but that isn’t the right solution.
The bed isn’t warped, the axes are straight and I don’t have any belt problems either.
I’ve learnt quite a lot over the past few years, but I still can’t get this problem sorted. Can anyone point me in the right direction to sort out this alignment issue (levelling the bed automaticly)
Make sure all four screw are tight. with 0.74mm, your bottom left corner may just be loose by the tiniest amount.
After that, you could try printing shims to put under the corners that are lower to bring them to the same height of the higher ones. (or buy metal washers of the specific thickness required)
I did that with my Ender3 V3 KE. Mine had a slant with 1.2mm difference between the left and right side out of the box. It was awful.
What I did is took the value of the higher of the corner and for the three others, I calculated the difference and printed shims of the value I got for each corner.
Now the more tedious task is removing the bed : putting the shims in place.
Be careful with the back left corner of the bed (the one with the electrical cables) and unscrew the bed from the printer, placing the shims and putting it back in place.
Since mine had a slant on the X axis, I leveled it beforehand by moving one of the Z rod on it’s own but should not be necessary in your case since your picture shows that the X axis is off by 0.05mm. But for precision sake, you could try and to that to.
After all that is done, Do a full calibration (Z offset first, then bed level) and check if the bed is at a better level than before.
Here is a video from creality (using the V3 SE but still same procedure) https://youtu.be/iaExzAYR_Fo
you may skip the first minute of this explanation video if you wish
