Ender 3 v3 KE software troubles
Issue Description
  • My Ender 3 V3 KE printer is displaying a warning:
“Memory is running out, clear it.”
  • I ignored this for a few days.
  • After downloading another G-code file via the web interface, the printer rebooted itself.
    • It seemed like a factory reset, as I saw screens for:
      1. Language selection.
      2. Accepting usage rules.
  • Problem During Network Setup:
    • During the network setup phase, the preloader appears and stays indefinitely.
    • It doesn’t proceed, no matter how long I wait.
Steps I’ve Tried
  1. Followed the instructions to skip the self-check as per Creality Wiki:
  • Created a file named debugmode_JumpSelftest or factory_reset on a formatted flash drive.
  • Inserted the flash drive into the turned-off printer.
  • Powered the printer on.
  • Result:
    • The setup screens reappeared; skipping did not work.
  1. USB Flash Drives Tested:
  • Tried multiple drives:
    • 500MB, 4GB, and 32GB, all pre-formatted.
  • Observations:
    • Printer detects the USB.
    • Removing the flash drive shows:
“USB is disconnected.”
  1. Firmware Update Attempt:
  • Wrote the firmware image file to the USB drive.
  • Inserted the USB into a working printer.
  • Result:
    • Received a prompt for updating firmware:
“Current version and available version for update. Do you want to update?”
* After selecting "Yes," an error occurred:
“Update error.”
Questions
  1. How can I perform a full reset to fix everything?
  • Can I disassemble the screen and press buttons on the board to reset?
  1. If I buy a new printer screen, will it solve the problem?
Такая же проблема( Ждём какого-то решения(
Получилось решить проблему с помощью разбора и перепрошивки самого экрана по инструкции: Brick Rescue/Wire Brushing Process | Creality Wiki
Только не повторяйте моих ошибок, когда открываете крышку экрана, не заденьте шлейф тачскрина)) Мне пришлось его паять. И используйте для прошивки качественный дорогой usb провод. Из-за плохого провода мне показывало ошибку и я думала, что проблема в чем-то другом.
Привет
Приятно
видеть, что вы нашли решение.
Удачной печати и счастливого Нового года :slight_smile:
Ура.
