I have had my printer for 1 month, but have noticed now that the printer will start printing 3CM from the bed. I can see it doing the leveling and the nozzle will touch the bed, but when starting it will print in mid air. Not sure what is wrong. Sometimes the printer will print fine, other times it will be 3CM too high.
I worked out what the issue was, the power cord for the hot end is getting caught on the filament role when the filament is new. If I print the same STL 3 times, 1 out of the 3 will start to print 3cm from the bed. I actually think this is a bad spool location design, with all the other power cords in the way.
