Ender 3 V3 Plus + Co-Print 8-Color Kit (Klipper) — Working CFGs?
I’m looking for someone who is using a Creality Ender 3 V3 Plus with the Co-Print 8-color upgrade kit and has it working without issues.
I’m new to 3D printing and I managed to get the integration partially working after a lot of trial and error and some custom changes to the cfg files. However, I’m still running into problems.
I already tried the cfg files provided by Co-Print for this integration, but from what I can tell they use a generic base meant for multiple printers. Because of that some features don’t work as expected and other settings seem incompatible with the Ender 3 V3 Plus specifically.
Before I keep tweaking things blindly, I wanted to check if anyone has a stable, working setup and would be willing to share their cfg files (or at least the relevant sections).
If you’re running this combo successfully, any help or shared configs would be greatly appreciated.
don’t modify the cfg files
it works out of the box with this firmware; Ender 3v3 KCM Set Setup Page | Co Print Wiki
I was contemplating adding a Klipper colour kit but now the Sparkx is available I’m indecisive to whether an add-on is worth the trouble. The 3 V3 plus cost almost the same price as the colour kit.
There are 2 firmware versions in the link you provided, I tried both, they don’t work with the .cfg files downloaded from there.
