Ender 3 V3 Plus Forced Pause
I recently switched to a 0.6 mm nozzle to pring some carbon fiber asa. On the .6mm nozzle profile the printer goes through its normal self checks, runs a wipe strip and then pauses for some reason. It does not do this on the .4mm profiles.
Any idea why it might be doing this?
what happens when you press start on the display when the printer has “paused”?
walk through all settings in CP, maybe you have changed something by accident.
You should be able to print ASA-CF with a 0.4 nozzle… At work we only use PLA-CF and we print that with the standard 0.4 nozzle without problems.
