Ender 3 v3 se flow problem
hi i have e3 v3 se with the nebula pad and i have overflow problem i tried to reduce the flow ratio and it wouldn’t changed at all (i printed at flow ratio 0.5) , and when i decreasd it more the printer extruded almost no filament. on top of that sometimes i have this problem and sometimes the printer prints well.
im using orca slicer because i have layer shift in creality print ,the layer shift is always at the same layers.
i replaced the cr touch because i thought maybe it was a first layer issue and it didnt help,
i tried to factory reset the printer and it also had no effect.
any ideas for whats the problem? i cant print anything because this problem.
I am having the same problem and using orca but do not have nebula
but my printer prints terribly first 5 layers then does giant layer shift then prints perfectly.
