Ender 3 V3 SE: Hyper ABS filament settings in Creality Print v6
Hi everyone. I’m having trouble with filament settings in Creality Print V6.
I have the Creality Ender 3 V3 SE printer and Creality Hyper ABS filament.
I am using Creality print v6.0.5.1840 and unable to add an ABS filament - I get the error message “You have not selected a printer or preset yet. Please select at least one.”
I have tried everything including V5 of the Creality print.
I can add the hyper ABS filament if I select another random printer eg the K1, and I can see it in the list of defaults when I change back to the Ender 3 V3 SE - but I cannot apply it to this printer.
I’m just wondering if anyone has come across this problem and if there is a work around?
ABS on an open printer, good luck. Nozzle 260C bed 105C, no draughts, you need an enclosure. PLA speeds should be fine. I only print ABS on an enclosed heated printer anything else would fail through layer adhesion and warping issues.
Thanks for the advice. I’ll give it a try with PLA speeds, those temp settings and a box!
