Ender 3 v3 SE Leveling and z offset issues
So just set this printer up, upgrading to ender3 v3 se from a ender 3 s1 pro.
When it first turned on, the head was almost max height. Auto leveling it didn’t even take it down the the bottom it just auto leveled in the air. I couldn’t change offsets and auto home took it to the middle top again.
I turned it off and manually adjusted the head till it was closer to the base and to where the little checker stick could hit the board. I auto leveled again and it did the same pattern just at the current height it was at. The offset or values shown didn’t change.
After every auto level the offsets are all -0.00 green. Moving z axis with the display works fine but the 0 is definitely just wherever I left it. Manual setting z offset doesn’t help if it’s not autoleveling?
Current bed is a glass one i took from my last printer.
theres times it wont let me move the z offset until i reset the configs. when auto homing or leveling, it never actually moves to touch the bed, it will auto level the air
When the V3SE does a bed level it will use the CRtouch initially which is fine on glass, then it should go to the front left corner where the nozzle presses onto the bed to activate a strain sensor, I have a feeling that bit of the autolevelling will fail. After a bit of further probing it will do the bed mesh level. Don’t know why it is levelling in midair.
