Ender 3 V3 SE says it's printing but it's not
no matter what file I try to print, the printer just dashes through the percentages and says it’s finished just a few seconds after the nozzle is heated to the desired temperature.
Does anyone have an idea of what’s causing the problem?
edit: in case people ask
I did install the firmware 1.0.4 out of creality’s website
The printer displays correctly the printing time and the required filament length
I live in the EU so I switched the voltage to 230V
I tried to use the “extrude” option in the menu, and it made some filament go through the nozzle, meanwhile when I tell the printer to print something, it will not make any filament go through the nozzle
Hi @yosh_y and welcome to the forums.
Try shortening the filename on your gcode file. It could be that the filename is too long and the printer cant read the file correctly.
Hi @Nikoli and thanks for the reply
sadly, naming my file a.gcode or anything different produces the same effect.
I uploaded a video about what the display shows https://youtu.be/38AjgwJyLkY
if I use prusa slicer or creality print, it will also dash through the printing percentages and say the printing time is zero and required filament is zero (before printing, in the file selection)
meanwhile, if the gcode file was generated in cura, the info in file selection displays properly
If you can, try to connect a PC/Laptop/Raspberry pi to the machine through the USB-C cable with Octoprint. Then upload a file or just send to print from the SD Card.
Then take a look at the Terminal Tab and if we are lucky enough you will see the error code if exist.
Once my printer didn’t want to print too(I have the same model) and the terminal said the error about leveling the bed (you know this printer before almost any operation do the auto home) and that’s why the Mesh of the calibration was empty or at least the Printer thought that.
To solved it I upgraded the firmware to 1.0.6, started from scratch the bed leveling after completion go to Control–> Store configuration and try again.
thanks for the advice!
I’ll try to use octoprint, I’ll post news right after
It’s unfortunate that the firmware 1.0.6 shouts at me “CR Touch problem. Contact customer service” as soon as I power my printer on, that’s why I went back to 1.0.4
octoprint console says this
Recv: echo:busy: processing
Recv:  T:195.34 /195.00 B:50.01 /50.00 @:43 B@:18 FAN0@:0
Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
Send: M27
Recv: Error:!! STOP called because of BLTouch error - restart with M999
Changing monitoring state from "Printing from SD" to "Error"
Send: M112
Send: N2 M112*35
Send: N3 M104 T0 S0*34
Send: N4 M140 S0*97
Changing monitoring state from "Error" to "Offline after error"
Connection closed, closing down monitor
So at the end the firmware 1.0.6 wasn´t faulty, seems like indeed your printer has an issue with the CR Touch. Try to open a case with creality support (you will need a lot of patience) to see if they can send you another part asa a warranty if it is still cover.
Also in the meantime you can double check the connection to the board and see if its just a bad connection/signal between the probe and the board.
Just want to mention that I have the same issue as described here, even with the reply of Cura vs Creality slicers giving different display settings. I didn’t try Octoprint (can I run it without a Raspberry Pi without too much hassle?).
I did get a refund for my printer and bought an ender 3 neo. Apart from scratching the glass once because of bad Z-leveling, I didn’t run into any other issue with it.
I suggest you either reach creality support or get a refund and completely change your printer
For what it’s worth, I’ve had this problem multiple times since I got my printer a few months ago. Each time it turned out to be a typo in the gcode file. Once a semicolon was missing where it should have been and this time there were extra spaces on the blank lines. After removing those with notepad and resaving the file it worked fine. Not sure if this is an issue with the slicer itself or due to the way the person designed it, but just another thing to check.
Yeah, well scratch that. I thought it was an issue with the gcode, but it was just coincidental. I’ve printed something fine and then the next time it won’t print. Seems to be random too. Only way I get it going again is to power cycle it and make sure to turn the calibration on when starting the first print of the day, then it seems fine for the rest of that run cycle to just print without calibration. But as soon as I turn it off for the day, its a crap shoot if it’s going to work again the next day without fiddling with it. Why is it that any hardware with the name ‘printer’ in it, has to be cantankerous? :stuck_out_tongue:
Did anyone ever find a way to fix this? My printer does the first print of the day fine, and then no matter what I do it just speeds through the print like shown in the link above.
It isn’t the file name or sd cards fault because I’ve tried files that worked before and directly plugging it in to my computer.
In stopped printing for a while and can’t back to this problem and it never did it before. If I need to buy a new part I will do that, but I just want it fixed.
Yes! I finally “fixed” mine just by doing certain things in order. After turning it on for the day I set it to home itself (under Prepare). Then, for the first print of the day I make sure I check the box to set Calibration to ON before hitting confirm. Prints fine. Then for each print until I turn the machine off I can print again but leave Calibration OFF. weird but this process seems to have fixed it for me. Hope it helps.
I have one fairly used one that is doing a lot of printing. Starting doing this few months ago. For me I just found out it was sticky CR Touch Auto Leveling Sensor. Either you manually extend sensing stick and brush it with some alcohol or just replace it. Mine is ok after brushing/wiping it with alcohol. It is not sticking anymore and autolevel procedure can be started without fault.
