The Ender 3 V3 SE and Ender 3 V3 KE are the latest additions to Creality’s Ender 3 series of 3D printers. Released in the fall of 2023, these printers offer a range of advanced features and functions.
This article aims to guide you through the similarities and differences between the Ender 3 V3 SE and Ender 3 V3 KE, to help you decide which one is the better choice for your needs.
Ender 3 V3 SE vs KE
The Ender 3 V3 KE introduces a range of impressive enhancements that distinguish it from its predecessor, the Ender 3 V3 SE. This 3D printer is designed with a strong focus on precision and user convenience. Here’s a brief overview of the differences between the KE and SE models:
| Model | Ender-3 V3 SE | Ender-3 V3 KE |
| Printing Technology | FDM | FDM |
| Build Volume | 220220250mm | 220220240mm |
| Product Dimensions | 349364490mm | 433366490mm |
| Package Dimensions | 575390235mm | 502409280mm |
| Net Weight(kg) | 7.12kg | 7.8kg |
| Gross Weigh(kg) | 9.14kg | 9.9kg |
| Build Surface | PC Spring Steel | PC Spring Steel |
| Display Screen | 3.2’’ Color Knob Screen | 4.3" color touch screen |
| Resume Printing | Yes | Yes |
| Filament Detector | No | Yes |
| Dual Z-axis | Yes | Yes |
| Leveling Mode | Auto | Auto |
| Mainboard | 32-bit | 32-bit |
| File Transfer | SD Card | USB drive, LAN, Creality Cloud APP |
| Supported Filaments | PLA/PETG/TPU(95A) | LA, PETG, ABS, TPU(95A), ASA |
| Heatbed Temperature | 100℃ | 100℃ |
| Nozzle Temperature | 260℃ | 300℃ |
| Rated Voltage | 100-120V~, 200-240V~, 50/60Hz | 100-120V~, 200-240V~, 50/60Hz |
| Voltage Base | 24V | 24V |
| Rated Power | 350W | 350W |
| Max. Printing Speed | 250mm/s * | 500mm/s |
| Typical Printing Speed | 180mm/s | 300mm/s |
| Max. Acceleration | 2500mm/s² | 8000mm/s² |
| Extruder Count | 1 | 1 |
| Nozzle Diameter | 0.4mm (default) | 0.4mm (default) |
| Layer Heigh | 0.1-0.35mm | 0.1-0.35mm |
| Printing Accuracy | ±0.1mm | ±0.1mm |
| Filament Diameter | 1.75mm | 1.75mm |
| Formats for Slicing | STL/OBJ/3MF/AMF | STL/OBJ/3MF/AMF |
| Slicing Software | Creality Print, Cura, Simplify3D | Creality Print, Cura, Simplify3D |
Ender 3 V3 SE vs KE Similarities:
Both printers share many common features. They come equipped with Creality’s Sprite direct drive extruder, which is known for its reliability and ability to print flexible filament such as TPU. They also feature automatic bed leveling enabled by the Creality CR-Touch bed leveling sensor, which ensures consistent and reliable printing.
Another shared feature is the standard Cartesian motion system, which is the most commonly used motion system for consumer 3D printers.
- Build Volume: Both printers offer a similar build volume, with slight variations in the Z-axis.
- Direct Drive Extruder: Utilizing Creality’s Sprite direct drive extruder for reliable and flexible filament printing.
- Automatic Bed Leveling: Equipped with the CR-Touch bed leveling sensor for improved bed calibration.
- Motion System: Utilization of a standard Cartesian motion system for consistent 3D printing.
- Dual Z Lead Screws: Both printers feature dual Z lead screws for even gantry raising.
- Linear Rods for Y Axis: Reducing vibration for high-speed printing.
Ender 3 V3 SE vs KE Differences:
There are however, some notable differences between the Ender 3 V3 SE and Ender 3 V3 KE. The Ender 3 V3 KE comes with advanced firmware known as ‘Creality OS’, which enables high-speed printing without print defects.
The KE model also supports remote control and monitoring over WiFi, a feature not available in the SE model.
1. Controls and Firmware:
- Ender 3 V3 KE: Advanced “Creality OS” firmware based on Klipper, enabling higher print speeds and remote monitoring via WiFi.
- Ender 3 V3 SE: Standard firmware with a smaller screen and knob controller.
2. Print Speed:
- Ender 3 V3 KE: Advertised maximum speed of 500 mm/s, typical speed of 300 mm/s.
- Ender 3 V3 SE: Advertised maximum speed of 250 mm/s, typical speed of 180 mm/s.
3. Hot End:
- Ender 3 V3 KE: Capable of heating up to 300°C, featuring a more powerful 60W heater and a bimetallic heatbreak.
- Ender 3 V3 SE: Capable of heating up to 260°C, suitable for standard filaments.
4. Part Cooling:
- Ender 3 V3 KE: Dual part cooling fans for more even cooling.
- Ender 3 V3 SE: Single part cooling fan.
5. Bed Surface:
- Ender 3 V3 KE: Default PEI bed surface for smoother prints and easier part removal.
- Ender 3 V3 SE: Default PC spring steel bed surface, with an option to upgrade to PEI.
6. Size and Z Axis Build Volume:
- Ender 3 V3 KE: Slightly smaller Z-axis build volume (240 mm) compared to the SE (250 mm).
- Ender 3 V3 SE: Smaller overall footprint compared to the KE.
7. Filament Runout Sensor:
- Ender 3 V3 KE: Includes a filament runout sensor.
- Ender 3 V3 SE: Sensor available as an optional upgrade.
Ender-3 V3 SE Review
The Creality Ender 3 V3 SE is the latest version of the budget-friendly Ender 3 printer, providing a great choice for beginners due to its simple assembly and user-friendly features. Retailing at $199, the printer is packed with deluxe features such as advanced auto leveling borrowed from the K1 series and the S1’s extremely capable Sprite direct drive. The printer operates at a faster speed of 250mm/s, aided by a sturdy build and linear rods on the Y axis. The printer uses a traditional SD card for file transfer and comes with step-by-step instructions on the screen.
The Ender 3 V3 SE has a build volume of 220 x 220 x 250 mm and can handle materials such as PLA, PETG, and TPU up to 260 degrees. It comes with a full-sized SD card, a USB adapter, tools for assembly and maintenance, and a small sample of white PLA for your first model. The machine is 90% pre-built and only requires a few screws for complete assembly. Although it lacks Wi-Fi connectivity, its high-quality printing and user-friendly design make it a top contender in the budget 3D printer market.
Ender-3 V3 KE Review
The Ender 3 V3 KE 3D printer stands out for its advanced features, which include an X-axis linear rail for ultra-smooth motion and more precise printing. It boasts a Creality OS firmware, which is more advanced than the Ender 3 V3 SE’s. This firmware enhances print quality and user experience, reducing printing defects and optimizing filament flow. The printer’s interface is a 4.3″ touchscreen controller, offering a clearer and more informative display.
The Ender 3 V3 KE has a higher maximum printing speed of 500mm/s, achieved through firmware and hardware enhancements, making it a great choice for those needing faster printing acceleration. This printer can handle high-temperature filaments due to its upgraded hotend, which has a nozzle temperature limit of up to 300°C, ideal for printing with materials like nylon.
The Ender 3 V3 KE offers three convenient connectivity options: USB drive printing, data-secure LAN printing with WiFi, and cloud printing. Other features include dual fans for rapid model cooling, quick assembly, one-tap self-test, auto filament loading, and hands-free auto-leveling. In conclusion, the Ender 3 V3 KE is an excellent choice for high-quality and efficient 3D printing.
Which one should you buy? Ender 3 V3 SE or Ender 3 V3 KE?
The choice between the Ender 3 V3 SE and the Ender 3 V3 KE depends on what you value most in a 3D printer.
If you are a beginner, budget-conscious, or prefer simplicity, the Ender 3 V3 SE is a great choice. It offers high-quality printing, user-friendly features, and is easy to assemble.
However, if you require advanced features like faster printing speeds, the ability to handle high-temperature filaments, and various connectivity options, then the Ender 3 V3 KE would be a better choice. Though it’s likely to be more expensive, its advanced features and enhanced user experience could justify the extra cost.
In summary, your decision should be based on your specific needs, budget, and level of expertise in 3D printing.
Conclusion
In conclusion, both the Ender 3 V3 SE and Ender 3 V3 KE are impressive additions to the Ender 3 series. The SE offers an affordable option with many advanced features, while the KE provides additional benefits for a higher price.
The Ender 3 V3 KE’s advanced firmware, higher print speed and user-friendly features make it worth the extra cost for most users. However, if the price is a major factor in your decision, the Ender 3 V3 SE is also a solid choice.
