Recently got the Nebula kit for my Ender 3 V3 SE. What printer profile, in Creality 3D Print slicer, do you pick?
The 3 V3 SE is there but not with Nebula. Under the Nebula tab the 3 V3 SE is not listed. Neither under the Sonic tab as I have heard Nebula and Sonic run the same.
Would like to print with this printer with the upgrade I added to it cause the other profile only uses Marlin instead of Klipper like the Nebula is supposed to add…
Hi
Try downloading the Beta Creality Print software.
As you will see this has specific settings for the V3 SE with Nebula
I have just installed this and it seems fine.
The revised Gcode solved some of my issues, so good luck.
