Hey! I just purchased a Creality Ender-3 V3 SE 3D printer and I put it together but when I started it up and selected English it started the Auto Z Offset and it would center and lower. Then it would move to the front left corner and the cr-touch would stick out a couple times as the screen would reset and it would restart the process. What should I do?
Hello @KaiL …! ![]()
First thing to check is the voltage switch…
Set on wrong voltage…? Happens a lot… ![]()
Thank you so much!!
Go over every part of the machine and make sure bolts and parts are connected properly…
Get familiar with how it’s put together…
It will save you a lot of problems later…
Have fun…! ![]()
