Can anyone tell me what z offset the Ender 3 V3 SE ships with, i mistakenly moved it and can’t remember what it was thanks
Run a bed calibration, it should make its own z-offset by using the CRtouch probe and the strain sensor in the front left corner. Once that is setup you may want to manually adjust the z-offset by 0.05/0.1mm to get the perfect squish.
Thank you, I will try that again
If you make any changes like a new build plate or a new nozzle you should re-run that calibration as the z-offset may change again. Same with big temperature changes, my printers are in the shed and the chassis will be different between summer and winter so I wouldn’t be surprised if I have to re-run bed levelling just because of that.
