Ender 3 V3 Touch Pad cable
Does anyone know what size the IDE cable for the touch screen is? I want to put it in an enclosure and would like to get and extension cable to mount the touch screen outside of the enclosure. Also with the power supply being internal will it be fine inside of an enclosure or should it be moved to the outside as well.
Really 27 days and no one has these answers…
That’s an answer I would also like to have for the same reason. I dont want to enclose the printer and leave its eletronics frying inside. My plan was to build an enclosure and leave the printers botton exposed so it could be safe from the heat but without a cable extension, the project is stalled
In my case I bought a 40 pin extension cable from Ebay for less than $10, and it works like a charm. Even the touchpad works.
40Pin To 40Pin ZIF 0.5mm Connector Adapter With Extension Flat Cable FFC Extend
Here are some photos:
NOTE: The touchpad cable is attached with strong glue, I used alcohol to remove the cable without damaging it.
