Hello All. My 3v3 Plus was printing at a normal rate (fast). Maybe because I did something wrong in the slicer (Creality), but the simplest files take hours instead of the usual minutes. Can someone share a profile or detailed settings I should be using?
Thank you.
When you are in Creality Print check in the set up section that the layer height setting has reverted to 0.08 instead of 0.20 or higher. My machine did this after a software update once and boy did that slow things down. Print quality was great though LOL
I had a replacement 3v3 plus yesterday. I thought it was slow. Compared the print time with the previous 3v3 plus and found that it takes a 150% longer! The last printer took 8 hrs for printing an item, this new one takes 12 hours. Any thoughts?
