Ender 5 Max Enclosure
When will Ender 5 max enclosure become available?
Has anyone used it with ABS? What is max temperature you are able to reach?
I have the enclosure, it is available in the store and 3rd parties. I am using with ASA with no issues.
Hasn’t been available in store for past month even though they have it on sale for $122. Other stores are showing august delivery.
Creality recently removed it from the website. I wonder why
Finally got it on ebay.
Unfortunately right panel was cut wrong and bows.
I have a Ender 5 max with a enclosure….printing ABS hyper (hotbed 105C° and hotend 260C°), had trouble with heat creep, after about 45min of printing the filamant gets jamed between the extruder and the nozzle….I played with the settings hotter and colder but it keeps on happening except with very small prints. fyi I’m now a expert on taking apart the print head (extruder, nozzles, heater block and fans) with all the jamming…..The only way I’m able to do get proper prints is by printing whithout the lid and removing the silicone sock on the hotend…..If there is another way please let me know….
You’re lucky you are getting electronics shutting down — I print long prints, about 25h - and guaranteed a crash of some sort. Whether a K 2001 or generic “spray head communications” error. And this last print it just stopped 2.5 layers from completion (28h print - 1.4kg used). And a power cycle to reset of course resumed: The printer seemed to recall the world coordinates okay - but the print recovery started printing at the wrong slice location; almost like there’s a gcode cache that gets lost with a power cycle.
Notably, a similar thing happens changing filament: layers get lost.
You are having this issue because the enclosure traps too much heat, and there is too much filament inside the enclosure, so it heats up and gets too soft for the extruder to grip. Remove the lid to let the heat out and keep the filament tube cold enough to work, or you could potentially make a higher ceiling, but I don’t believe it would work well. I had the same issues with my printer, so I removed the top panel and have had no issues.
