I am having issues with filament ruining my heat block. My printer is new (two weeks in use) and I am on my 4th lower heat block.
Today I printed a model that took about 1.5 hours using Creality PETG white filament. The unit was cooling down for about 5 minutes while I cleaned the heat bed, then tried to start my next print job. It was running for about a half hour when I noticed that there was still only the first layer put down. It was going through the motions but nothing was coming out. I thought the Nebula camera had AI that should have stopped this.
I had to fully disassemble so I could access the gears to remove the tiny bit of plastic stuck in there. I had to clear the white tube as well. I have not started to print again but this has been an ongoing issue.
This is now my 4th heat block, the previous 3 were completely ruined with plastic having blobbed all up into things.
I have also noticed what I believe is a major manufacturing issue. On the lower heat block there are the 4 wires that come off of it and terminate with two connectors. The larger of these wires have heat shrink on them. These are the wires attached to the ceramic tube for clarification. The problem I am finding is that the heat shrink is far too short leaving plain wire exposed and if the two wires are allowed to short together you get an error on the printer. On heat block #3 I used black electrical tape to keep them from shorting. On my most recent one I used a tube of silicone gasket to insulate them from each other and just gave it time to dry before using it. At $25 a pop I am starting to regret my purchase. Creality did provide me with 1 free one. But I feel I should be able to get much more than 72 hours out of these.
What do others do to prevent clogging in the heat block or the gears?
My most recent attempt at a fix was to issue some G-Script code at the end of the job to alter the cool down delays and retraction. I still had to take everything apart, but the block did not appear to be ruined this time. Has anyone else been seeing the issue with clogging or the bare wires and shorting?
The code I am testing for PETG end G-Code is as follows:
G91 ;Relative positioning
G1 E-2 F2700 ;Retract a bit
G1 E-2 Z0.2 F2400 ;Retract and raise Z
G1 Z5 ;Raise Z more
G90 ;Absolute positioning
G1 X395 Y395 F6000 ;Present print
M106 S0 ;Turn-off fan
M104 S0 ;Turn-off hotend
G4 S35 ;Wait 35s - PETG stays soft longer, needs more cooling
G1 E-18 F150 ;Shorter, slower retract - PETG is stringier and grabs more
M140 S0 ;Turn-off bed
M84 X Y E ;Disable all steppers but Z
