Sliced model in creality slicer with the pause on some layer to change the filament.
After filament changed I press resume button, and when printer done printing first layer (after the filament changed not yhe first layer of the model) it takes the extruder to the left corner and gives me this error: printing file coordinate exception. Tried to slice it with m600 command, but after i change the filament it just do the same without any error, just takes the head to the left corner and pause the print.
Made a bed calibration, same problem but without any error. Head just moves to the left corner and pause the print.
Made a profile in orca, added a simple cube, sliced with pause on 25th layer, it takes the head to the corner and after I press resume button, it prints one layer and goes to the same corner. So it looks like the printer think that it needs to pause on every layer after 25th. Anyone can help me with this? @Creality3D @CrealityOfficial
I have ender 5 max to.
I have same problem when I set filament change. It pause and stay in left corner. The whole screen is not translated. If I set it to silent mode it keeps speeding up back to 100%. So if I want print in silent mode I have to manually reducing speed all the time. And some times in slicer window speed goes to 40%. I cant even set it to 40%.
One big problem is if you print petg and set bed temp to 70 degrees. Machine starts to print with 45 degrees and start to heat bed when it already start printing to 70. Because of this parts wont stick to bed.
Other problem is that bed is bend in the midle.
It is ok machine but firmware is rubbish. I can’t wait to go on klipper firmware.
You can prehit the bed before you start printing. Btw to solve problem with this error you need to calibrate the bed. It helped me with this error, but it still goes to pause after you press resume and printer prints one layer.
Yes I know that. But when I preheat bed and send something to print printer cool down bed to 50 degrees and then to start print.
How do you send the file? Usb,web interface or creality slicer?
It is no matter how. Look I’m not beginner with printers…I even try with orca slicer and it is all same. Firmware problem…
We run the same firmware, but I can prehit and use this temperature to make a mesh map, but you can’t. Si probably you going something wrong. Yes there is a problem with pause, but not with using temperature to make a mesh map.
Prehit your bed with web interface and after the bed is hited send command from web interface yo make a mesh. Save the mesh via wrb interface,reload the klipper via web interface and only after this print.
E5max does not have access via the web interface.
Yes it is. Even with not rooted firmware.
Pokud udělám root tiskarny a nainstaluji čistý klipper, můžu se pozdeji vrátit k originálnímu systému ?
