My Ender-5 Max lost wifi signal after initial hookup (when the router showed connection to the printer as "Ender-5 Max and it also showed in Creality Print as “Ender-5 Max”.
After being turned off and relocated further from the router the printer showed connection to the wifi router with medium signal but now as “ingenic -4A05”. Creality Print couldn’t see the printer until the router was re-set several times.
Hope this helps anyone else having connectivity issues. Cheers.
Probably it’s not a problem with a printer,but with your router’s settings.
Why would the printer identify as “ingenic-4A05” now as opposed to identifying as “Ender-5 Max” when it was first set up?
Because probably there is an engenic semiconductor chip.
