When I first fitted a microswiss NG I had change the e-steps. Then I upgraded to a Sonic Pad and had to change the rotational distance instead. Retraction distance should be fine at 1.0, mine is lower at 0.8. I lower the maximum retraction count from a 100 to 20, helps stop gnawing at the same spot on the filament.
