ENDER 5 PLUS Touchscreen display
I have a Creality Ender-5 Plus with a V4.2.2 mainboard and a GD303 chip. When I turn it on, the screen briefly displays the message “FAULT”, then switches to a blue screen, and eventually shows the interface in Chinese. The touchscreen is completely unresponsive.
I have tried updating both the mainboard firmware and the screen firmware using the official package Ender-5 Plus-Marlin2.0.8.3_HW_V4.2.2_SW_V1.0.7. For the screen, I copied the entire DWIN_SET folder onto a 16 GB microSD card formatted as FAT32 with a 4096-byte allocation unit size, and inserted it into the slot on the back of the display.
The problem is that the firmware update does not seem to start at all when I insert the card containing the firmware files. No progress bar or any other indication appears to show that the screen is reading or updating the firmware. After attempting the update, the screen remains exactly the same. I have also tried turning on the printer without the card inserted, and the behaviour is identical.
Has anyone experienced this issue? Could it be caused by the DWIN firmware being incompatible with the specific screen revision, the display not reading the SD card, a faulty screen, or a communication problem with the mainboard? How can I troubleshoot this?
