Ender 5S1 no extrusion when printing but engine OK
Hi,
My ender 5S1 refuse to extrude when I print, but extrude when I do it manually from screen (so motor is OK and nothing is obtured)
I already :
Change filament
Change slicer
Change File
Check cables
Reset motherboard using factory reset on screen
Anyone has an idea ?
(sorry for english)
I am facing the same problem. The motor is okay but when I print it does not feed the filament.
I am sure the motor is okay because I changed its cable for the cable of Motor Z then I homed. The motor ran.
Have you taken extruder apart and checked the gears? Sometimes the gears get damaged and will work manually. Make sure gears are operating correctly and making contact with each other.
