Ender 7 Problem with replacement
Hello! how are they?
It’s my first time in this group since no one has been able to help me so I came with my last hope.
The thing is that I have an Ender 7, and I would like to know which hotends are compatible with my machine, since I have not been able to find any and at most I have only found the complete KIT for 70 dollars! which for me is impossible and I only need the heating head. I hope you can help me and thank you very much!
Just know if any hotend is compatible with my machine, or simply throw it away and buy another one.
What I need is the Hotend, the nozzle heater, nothing more, nothing less, everything else is perfect, since the cable was accidentally cut.
Is it just the heater cartridge that has broken most of the hotend is just an aluminium block with your brass nozzle screwed in. The bits that break are the heater, thermistor and nozzle. To be honest I had never heard of an Ender 7 before but a quick search on Reddit has an owner changing the hotend for a Spider v3 Pro which should be fairly cheap on Aliexpress.
It is the heater more than anything, which is connected with cables, which sets the temperature and provides the energy to heat…The heater itself is good, what happens is that the cable from the depth of the heater came loose. hole and it is now impossible for me to fix it :C
Thank you very much for your quick response! I’ll see if I can find something :c
