Hi All,
I am relatively new to the world of 3D printing - I got my Ender -3 V3 in June this year and have been happily printing various parts without any issues…until now. I have tried printing some components this week and have been getting consistantly poor results, it seems like the layers of the models aren’t sticking together. I have attached a printer of the sample boat that comes with the printer, up unti now it would have printed beautifully but as you can see it is now pretty terrible. As far as I’m aware no settings have been changed, so I wondered whether anybody here has any ideas what might be causing this?
Thanks in advance.
After Bed level print a Level Tester for your printer you can search any model you lilke for your setup, for example here. During the Bed level check the Z offset and adjust it to be tight enough to have a good layer.
If it just started to happen for no reason, i have had this happen before, it could be some bad gcode sitting in your printer. If you use the printer menu and reset to default option, and do the calibration tests before using it, it may fix your problem. Also make sure you have the right filament selected in your slicer.
In addition to adjusting the Z-axis offset, you can also reduce the fan speed to prevent excessive cooling. If the layer height is set too high, the 3d printing filament may not bond fully. Generally, the layer height should be about 20% smaller than the nozzle diameter.
