Hello all,
I own two Creality printers, and recently my Ender S1 encountered a problem after a failed print. Here’s what happened:
- The print failed, resulting in a large blob of melted plastic encasing my hotend.
- I cleared the hotend by heating it and carefully using a hot knife.
- After reassembling the extruder assembly, I attempted to print and noticed that the extruder motor is not spinning.
- I observed that the motor works after a printer restart and before Z bed homeing, but after the CR touch touches the bed, there is no extrusion.
What I have checked so far:
- All connections have been checked and are okay.
- Motor continuity has been checked and is okay; the motor is not shorted.
- Voltage on the stepper motor drivers has been checked and is all good at 0.95 on E.
- Voltage on the head where the motor plugs in has been checked and is all good at 24V.
- I also tried using the CR touch from my V3 SE, but there was no change in behavior.
- Furthermore, I attempted using the E motor from the SE, but there was no change in behavior.
- Klipper and Marlin firmware give same result.
I hope this helps in diagnosing the issue with my Ender S1. Thank you for your help.
