when trying to set Z- offset it wont go low enough to bed. When I do a 100x100 test can lower Z to correct value but it never stays. As soon as I send something new to print the value changes and the print doesn’t stick to the bed . How can I lock in my Z -offset?
If you have web ui backend, you save the new probe offset otherwise you can set offset value via slicer.
If this is still happening, check to see if there is a value set in your slicer that is overriding the value in the printer?
