Hello,
When using the newer v5.0 (Creality Print), I am receiving errors that I already had to fix in the last version of the source, e.g. Creality Print v4.3.x or whatever…
With the v5.0 source of Creality Print, I am receiving E:0004 and E:0500.
Is it short of a OpenGL install or is my graphics card at fault? Or…is this indeed a hardware issue(s)?
Seth
P.S. Anyway, if someone could make me understand why it is the v4.3.x and the v5.0.x source of Creality Print makes for exactly the same error codes when initially starting to print, that would be nice. Also, I have had to slow down my print speeds on the K1C since reading about how fast
this printer can actually print. Without error, I can use v4.3.x of Creality Print at 100mm/s.
The Creality Cloud site does not, I repeat, does not allow for uploading of specific files any longer...
Is this normal? Or, should I just use the v4.3.x of Creality Print? You all lots of hardware and source out there that uses Klipper. I am glad you guys/gals are using Klipper. This is one further step to Open Source initiatives… yes!
Also...
With the v5.0 of Creality Print, I am receiving errors when v4.3.x prints 1/2 of the time. Is there a key or a future in the K1C or has Creality LTD. moved on for supporting this machine?
