Error 2569 Unknown Exception
Had a clog nozzle a week or so ago, and ended up changing the nozzle and everything seemed back to normal. Then a few prints later start seeing failed prints. A few times I was able to resume and complete printing. Then it would not print and would not extrude. Not much information to find related to this error. Took the extruder apart and testing the Extruder motor without the extruder attached. Servo would chatter and stop running and showing the 2569 error message. Bought a new Creality Ceramic Heating Block kit (Hotend) extruder, extruder servo motor, and PCBA Breakout module (PCB board). Tested the new servo against original - same issue, Replaced the PCB and the issue is fixed. Printer was purchased in Sept 2024 and has been working really well up until the nozzle clog. I had been running pretty consistent for the last few weeks. Just figured I would shared the info as it was hard to find anything on line and I need to get it back up and running.
Stan
I am not happy reading this. After some fillaments got stuck my extruder motor dont work anymore. Creality sending me a new motor dont hope the board is defect. Then i have to wait another week. This Tuesday the motor wil get delivered.
I bought a K1C in Sept 2024, and now I’m getting the same error. Mine happened 6 months after the last firmware update. Connections look fine.
Hi, i have the same error, do you find a solution to solve this issue, please ?
Thanks a lot again for this post, leave change de PCB without any result, I have change the extruder motor and it work perfectly again. Hope that can help someone in the future.
