Hello experts,
I have a stupid problem with my Ender 3.
Today I replaced a defective fan and installed a new nozzle, so far so good.
After restarting, everything works at first - except for auto levelling.
When autolevelling, it always stops at a random test point. The error message claims that the CR touch is causing the error, but I don’t think that’s true.
At the probe point, the Z-axis does not move down but stops at 10mm. It is clear that the CR-Touch then probes into the void.
The question is, why does it do this?
Homing and manual movement of the Z-axis works, no matter at which point and in which direction.
Both via the cntrol knob on the display and via Octoprint.
I can also print as normal, but it always stops at 10mm when autoleveling.
Nobody here with an idea?
