This worked for me. Thanks for the post!
I had the same leveling error and I also believe that the bed was the issue. Iâve printed several hundred objects for my business and have loved my V3 so far, so I was disparaging.
MY SOLUTION: Forgive my unsophisticated caveman techniques, but I TAPPED WITH MODERATE PRESSURE on the bedâs 4 corners with a small rubber mallet, did a firmware reboot, did both self-checks, and LO AND BEHOLD, itâs working like a champ again! Took all of 15 minutes? Good luck, but over the years, Iâve learned to mess with things as little as possible⊠âcause Iâm a cavemanâŠ
hi there. Anyone has 1.2.3.21 firmware? Canât find it on the official website.
Didnt been fixed. Again I had the same problem. I found an advice about control sockets whats under hotbed. I unplug and plug again all that sensor sockets. I think last four months along witout CL2529 fail I am using.
I have run into this code a few times. My solutions were always to rename the files before sending them to the print. I havenât run across the firmware related issues to this, so I believe QuietMikeâs recommendation is a pretty solid.
Thank you all for your responses.
I contacted Crealityâs technical support, who sent me the four strain gauges and the main board.
After changing them and updating the firmware, everything seems to be working correctly.
I had the same issue. Yesterday, I could print nothing. Today, I read through these post (as much as I had time too), and although many people asked âhow to install the previous firmware?â All I could seem to find was âdownload it from hereâ not how to install it.
So, today, I just reset the defaults on the printer and its working fine now.
What I am very curious about is âsince creality is who caused this issue, when will they have it fixed?â I spent a long time trying to get support, but there was no way to ask any live person a question.
I think the v3 plus has reached the end of its update cycle by the company. (Very sad its arrived soon)
error 2529 is a completely random error. My printer gives this error every time. And to fix it, I just unscrew and tighten two screws and itâs fixed. Itâs very strange and ridiculous.
There are other errors too.
Itâs a very nice and lovely device, but unfortunately they didnât spend much time troubleshooting it. There are a number of issues that even the company itself is not aware of and cannot fix.
We all have to deal with itđ„Č
And lastly, in my opinion, the most stable version of the deviceâs firmware is version 23.
To update the firmware, see this link.
would you have the 1.2.3.21 firmware? I cant seem to find it
Some said custom file and 3mf names with no special characters fixed It.
I will try this. Thanks so much, Iâm new to 3d printing and have had this problem a lot. I will also try back porting the software first though along with this.
hay all, need a copy of firmware 1.2.3.21. only thing on the creality web page is firmware 1.2.3.28. would realy help for someone to post the image or send me a copy.
thanks
Bonjour, jâai aussi depuis peu une erreur CL2529, un soucis avec le capteur de niveau qui subirait des interfĂ©rences externes ?!?! mais je ne vois vraiment pas quoi ! La solution semble ĂȘtre de downgrader le firmware. Actuellement câest le 1.2.3.28 qui est installĂ©. Je ne rĂ©ussi pas Ă trouver oĂč tĂ©lĂ©charger le prĂ©cĂ©dent (1.2.3.21). Si quelquâun a un lien, je suis preneur, et je pense ne pas ĂȘtre le seul ! A+ et merci dâavance
posee celdas de carga en la cama, son 4 estan debajo de la cama, al bajar el extrusor toca la cama y las celdas lo detectan, tenia el mismo problema y le solte un poco los pernos de la cama, y de los rodamientos lineales, estas celdas requieren que la cama este flexible un poco, si esta muy rigido la celda creee que esta con carga.
Tengo una Ender 3 V3 plus y tambiĂ©n todo el rato con el error Cl2529, hasta que en Chat GPT me indico que quizĂĄs tenias los pernos muy apretados en la cama y los soltĂ© un cuarto de vuelta y se arreglo (son 4 tornilos de la cama + 8 tornilos para el rodamiento lineal, queda con un mĂnimo juego y con eso las 4 celdas de carga puedes detectar la presiĂłn que ejerce el extrusor.
Still no links to 1.2.3.21?? Iâve searched everywhereâŠwhy would Creality remove the old firmware when the current version CLEARLY has issues (as weâre all experiencing on here).. HELP! Iâm stuck in the same boat with the CL2529 error message. Iâve had this Ender3 v3 Plus for 2 WEEKS and Iâve gotten this error message on EVERY print Iâve tried in the last 3 days. Nothing works.
So, I ran into this issue for the first time today on my v3 plus. Had it for over a year and 1100+print hrs so far. I had the code, and noticed some odd inconsistencies in my prints before the code kicked it off. Tried calibration of input shaping and leveling, nozzle wouldnât contact the bed and just go up. I ended up taking the bed plate off, unplugging the level sensor and strain gauges and all of my problems went away after reassembly. We will see for how long, but the gauges and level sensor are under 50usd for a kit so if required I can replace.
