Error FO2936 on all 4 filaments
I cannot get any of my filament slots loaded. I try different spools of color, Creality and generic, and nothing works. It was working just fine, but over the past day, nothing works.
I’ve only had this machine for 10 days now… why should I be running into this problem already??
Have you checked the things suggested in the wiki?
Where does the filament stop loading?
I have had mine for less than 7 days and only done 3 prints and I get this error also. I have checked everything suggested and cannot find a clog anywhere nor a reason for this error.
Can you manually feed the filaments thru each channel?
Any blockage? If you can’t feed it upward. You can also try to take out the PTFE tube and try to push in the other way to clear off the jam.
