ERROR Key 2510 - Ender 3 V3 KE Printer
Good afternoon everyone.
I bought my printer in July this year (Ender 3 V3 KE) and after 2 months of use it presented an error yesterday in the middle of printing and it no longer prints. Key 2510 - Sensor Temperature Error. I’ve turned it off and on again a few times, waiting a few hours, but the error message persists.
When researching I saw that it could be a bead temperature sensor problema but the printer is still under warranty (only 2 months of use). Has anyone experienced this problem? How to solve it?
Below is an image for review. I need help. I sent an email to brazil support but I haven’t got an answer yet.
Troubleshooting and solutions on the Creality Wiki
https://wiki.creality.com/en/cr-series/cr-10-se/troubleshooting/2507-2509-2510-error-trouble-shooting
Regards, Goldy
Ok. I believe that I have to open the printer in that case but if I open the printer to check if the heat bed temperature sensor is properly connected, troubleshoot the sensor’s wiring terminal, and the main board socket as mencioned I will lose the 1 year warranty. The printer is less than three months. How do I proceed in this case? Could you help me?
Hi, I do have exactly the same problem. I bought mine end of June. Is your problem solved yet?
I sent an email do creality post sales and after that I sent it to maintenance indicated for them. I’m still waiting…
That’s bad news. I will keep you posted if there is progress in my case.
Hi Marcell,
Creallity service center did reply to me with a lot of questions. But I could solve my problem (replace the heat bed with sensor under warranty) through my local distributor. Hopefully you will be able to do the same.
Hello.
Ok. Thank you for the information. Mine is still under maintenance. I’m waiting
I would let them know as soon as possible about this.
CS@Creality.com or whomever you corresponded with firstly.
Creality Support Pages
Sorry you are having this bad experience.
