Hi all,
I have just configured my Sonic Pad on my Ender 5 Plus. A first print went fine, but I had to tweak some settings, due to my setup:
MB: Silent Board V2.2.1, Atmega2560.
Extruder: Bondtech DDX v3 Direct Drive
A new print seems to start fine (sliced in Bambu studio, transferred via USB).
However, at the end of layer 1, the pad gives an error and stops. This is the log.
20:34:42 $ SDCARD_PRINT_FILE FILENAME=“U_ddx3_ADXL345-v2.gcode”
20:34:43 File opened:U_ddx3_ADXL345-v2.gcode Size:2880105
20:34:43 File selected
20:34:45 // {“code”:"key61, “msg”:“Unknown command:M201”, “values”: [“M201”]}
20:34:45 // {“code”:"key61, “msg”:“Unknown command:M203”, “values”: [“M203”]}
20:34:45 // {“code”:"key61, “msg”:“Unknown command:M205”, “values”: [“M205”]}
20:34:46 $ QUERY_FILAMENT_SENSOR SENSOR=filament_sensor
20:35:03 // Filament Sensor filament_sensor: filament detected
20:38:39 !! {“code”:“key113”, “msg”: “Extruder not configured”, “values”: }
What could be the issue? In my printer.cfg, I do see an [extruder] part.
# !Ender-5 Plus
# printer_size: 350x350x400
# version: 3.6
# This file contains pin mappings for the Creality Ender 5 Plus.
# Ender 5 Plus stock uses a Creality v2.2 board, similar to CR-20 Pro.
# To use this config, the firmware should be compiled for the AVR
# atmega2560.
# See docs/Config_Reference.md for a description of parameters.
###fluidd set
[include cx_printer.cfg]
[display_status]
[pause_resume]
[gcode_macro PAUSE]
description: Pause the actual running print
rename_existing: PAUSE_BASE
# change this if you need more or less extrusion
variable_extrude: 1.0
gcode:
##### read E from pause macro #####
{% set E = printer[“gcode_macro PAUSE”].extrude|float %}
##### set park positon for x and y #####
# default is your max posion from your printer.cfg
{% set x_park = printer.toolhead.axis_maximum.x|float - 5.0 %}
{% set y_park = printer.toolhead.axis_maximum.y|float - 5.0 %}
##### calculate save lift position #####
{% set max_z = printer.toolhead.axis_maximum.z|float %}
{% set act_z = printer.toolhead.position.z|float %}
{% if act_z < (max_z - 2.0) %}
{% set z_safe = 2.0 %}{% else %}
{% set z_safe = max_z - act_z %}{% endif %}
##### end of definitions #####
PAUSE_BASE
G91
{% if printer.extruder.can_extrude|lower == ‘true’ %}
G1 E-{E} F2100{% else %}
{action_respond_info("Extruder not hot enough")}{% endif %}
{% if “xyz” in printer.toolhead.homed_axes %}
G1 Z{z_safe} F900 G90 G1 X{x_park} Y{y_park} F6000{% else %}
{action_respond_info("Printer not homed")}{% endif %}
[gcode_macro RESUME]
description: Resume the actual running print
rename_existing: RESUME_BASE
gcode:
#### get VELOCITY parameter if specified ####
{% if ‘VELOCITY’ in params|upper %}
{% set get_params = ('VELOCITY=' + params.VELOCITY) %}{%else %}
{% set get_params = "" %}{% endif %}
G91 G1 E{E} F2100{% else %}
RESUME_BASE {get_params}
[gcode_macro CANCEL_PRINT]
description: Cancel the actual running print
rename_existing: CANCEL_PRINT_BASE
gcode:
TURN_OFF_HEATERS
G91 G1 Z4.5 F300 G90{% else %}
G28 X Y{% set y_park = printer.toolhead.axis_maximum.y|float - 5.0 %}
G1 Y{y_park} F2000 M84CANCEL_PRINT_BASE
[stepper_x]
step_pin: PF0
dir_pin: PF1
enable_pin: !PD7
microsteps: 16
rotation_distance: 40
endstop_pin: ^PE5
position_endstop: 360
position_max: 360
homing_speed: 100
[stepper_y]
step_pin: PF6
dir_pin: PF7
enable_pin: !PF2
microsteps: 16
endstop_pin: ^PJ1
position_endstop: 350
position_max: 350
homing_speed: 100
[stepper_z]
step_pin: PL3
dir_pin: PL1
enable_pin: !PK0
microsteps: 16
endstop_pin: probe:z_virtual_endstop
position_max: 400
position_min: -15
homing_speed: 10.0
[extruder]
step_pin: PA4
dir_pin: PA6
enable_pin: !PA2
microsteps: 16
rotation_distance: 7.71
nozzle_diameter: 0.40
filament_diameter: 1.750
heater_pin: PB4
sensor_type: EPCOS 100K B57560G104F
sensor_pin: PK5
control: pid
pid_kp = 25.159
pid_ki = 1.421
pid_kd = 111.330
min_temp: 0
max_temp: 265
max_extrude_only_velocity: 150.0
max_extrude_only_accel: 4000.0
max_extrude_only_distance: 200
[safe_z_home]
home_xy_position: 225, 180
speed: 100
z_hop: 10
z_hop_speed: 5
[bltouch]
sensor_pin: ^PD3
control_pin: PB5
x_offset: -45
y_offset: 0
#z_offset: 0
speed: 20
pin_up_touch_mode_reports_triggered: False
[bed_mesh]
probe_count = 6,6
algorithm = lagrange
# probe_count = 6,6
# algorithm = lagrange
speed: 150
horizontal_move_z: 8
mesh_min: 30, 0
mesh_max: 315, 350
# # probe_count: 5, 5
[idle_timeout]
timeout: 172800
[bed_screws]
screw1:30,40
screw1_name:1
screw2:325,40
screw2_name:2
screw3:325,295
screw3_name:3
screw4:30,295
screw4_name:4
[heater_bed]
heater_pin: PH5
sensor_pin: PK6
control: pid
pid_kp = 65.864
pid_ki = 0.706
pid_kd = 1536.277
min_temp: 0
max_temp: 130
[fan]
pin: PH6
[mcu]
serial: /dev/serial/by-id/usb_serial_1
# [mcu rpi]
# serial: /tmp/klipper_host_mcu
# [adxl345]
# cs_pin: rpi:None
# spi_speed: 2000000
# spi_bus: spidev2.0
# [resonance_tester]
# accel_chip: adxl345
# accel_per_hz: 70
# probe_points:
# 150,150,10
[input_shaper]
#shaper_type_x = mzv
#shaper_freq_x = 80.8
#shaper_type_y = mzv
#shaper_freq_y = 77.2
[filament_switch_sensor filament_sensor]
pause_on_runout: true
switch_pin:PE4
[printer]
kinematics: cartesian
max_velocity: 300
max_accel: 7000
max_accel_to_decel: 7000
max_z_velocity: 5
max_z_accel: 1000
square_corner_velocity: 5.0
[exclude_object]
[gcode_arcs]
#resolution: 1.0
[include timelapse.cfg]
[include cx_gmcro.cfg]
#*# <---------------------- SAVE_CONFIG ---------------------->
#*# DO NOT EDIT THIS BLOCK OR BELOW. The contents are auto-generated.
#*# [bltouch]
#*# z_offset = 2.300
#*# [bed_mesh default]
#*# version = 1
#*# points =
#*# -0.357500, -0.242500, -0.170000, -0.123750, -0.092500, -0.292500
#*# -0.166250, -0.108750, -0.033750, 0.012500, 0.041250, 0.007500
#*# -0.121250, -0.075000, -0.021250, -0.008750, 0.007500, 0.017500
#*# -0.156250, -0.130000, -0.066250, -0.022500, -0.012500, -0.031250
#*# -0.107500, -0.148750, -0.078750, -0.101250, -0.046250, -0.007500
#*# -0.075000, -0.102500, -0.148750, -0.126250, -0.067500, -0.013750
#*# x_count = 6
#*# y_count = 6
#*# mesh_x_pps = 2
#*# mesh_y_pps = 2
#*# algo = lagrange
#*# tension = 0.2
#*# min_x = 30.0
#*# max_x = 315.0
#*# min_y = 0.0
#*# max_y = 350.0
#*# [input_shaper]
#*# shaper_type_x = mzv
#*# shaper_freq_x = 31.2
#*# shaper_type_y = ei
#*# shaper_freq_y = 36.2
Many thanks!
Tim
