I’m trying to etch a new design and I’m getting inconsistent burns depending on whether the ‘frame’ (hearts and squiggles, as seen in the image) is on the X-Axis or the Y-Axis.
They’re both the same layer in light burn, same settings. As you can see, the text also shows the same type of issue.
If I rotate the print, I get the same issue, X-Axis barely burns while the Y-Axis goes deep.
I’m aiming for a shallow burn because I want to do a paint fill, but only of the words and the hearts, the squiggles are going to stay dark.
Any suggestions for what I might be doing wrong here?
