EVA Foam and the Falcon 2 22w
Picked up some EVA foam from Michaels (Canada) the other day.
I used Lightburn with my Falcon 2 22w system to engrave and cut.
The engraving was done with a multi-mode layer: fill at 10000 mm/m with 10% power, single pass followed by line at 10000 mm/m with 5% power.
Cutting the 2mm EVA foam was done at 2800 mm/m with 40% power, single pass.
Cutting the 6mm EVA foam was done at 1400 mm/m with 80% power, single pass.
I got decent results with the above settings. Your mileage may vary.
These are the type of foam like the “puzzle floor foams” you can buy around?
If the puzzle floor foam is made out of EVA foam, then yes. Lots of puzzle floor mats are made out of rubber though and those are different.
Puzzle floor foam is quite a bit thicker. 12.7mm or 1/2" thick was the thinnest I could find with a very quick search. Also, the floor mats have a textured surface and I was specifically looking for a smooth surface so that I could engrave and layer the foam.
I used the 2mm EVA foam to make foam bottoms for coasters that I made.
I used 4 layers of the 6mm EVA foam to make an insert for my Shun carving knife set in a custom Japanese toolbox style box that I made for them. Each layer has a different profile cut into it
Wow! Great result!
The precision is great and looks professional!
Did you make the fork and knife and the wooden box too?
Just the box to put my Shun Premier 2-Piece Carving Set in. I needed a foam insert and the EVA foam worked out quite well.
I got the idea for the EVA foam inserts from Making custom toolboxes using a laser engraver on YouTube.
Great looking design & execution for the knife box!
Looks like you needed about 4 layers of foam to create the well for the knife & fork.
The laser has done a nice clean cut in the foam.
The link was interesting to look at, the guy mentioned the smell when cutting, how did you find it?
Thanks @Dave777.
Exactly 4 layers of 6mm foam were used. 1 and a 1/3 of the 12x18 sheets. The bottom layer didn’t need any enclosure cuts, just cut to size to fit in the box.
I didn’t really notice much of a smell, although I was running the laser in the enclosure with the fan venting outside, so that helped. After each cut was done, I let the fan run for a wee bit to vent out any residual smoke from the cut before opening up the enclosure to remove the part.
I had to cut everything on a 45-degree diagonal since the width needed was 452mm - too large to fit on the X or Y axis in the engraver.
