I’ve had too many fatal errors with CP 5 where I have the perfect material settings and then CP just wipes them out never to be seen again. This has caused major headaches. That being said: Is there a way to export “Material Settings” that I am not seeing? I want to have a record of Walls, speed, acceleration…settings. The only thing I am seeing in that panel is “Add, subtract, sync, edit and save as”. No export.
I needed this today and figured it out. Leaving this here for posterity.
For Creality Print v5: File > Export > Preset Config (exports all presets)
For Creality Print v7: File > Export > Export Presets (allows you to pick which presets)
Both export all settings as a ZIP archive with JSONs of each setting. They can be imported (even between versions) using the same process as before but using the “Import” menu.
