Hi Team Creality
I know my K2 plus has a small LED integrated in the extruder.
Is it possible to turn on the light from the extruder while changing filament? Maybe in the next software revision…
Thanks
Hi Team Creality
Thanks
I think it’s possible if you change the “Change filament G-code” a little bit. i’m not sure about the exact code, but i found it’s something like that. I found this code with AI.
[multi_pin LED_pin]
pins: PB0,PA12
[output_pin LED]
pin:multi_pin:LED_pin
pwm: True
cycle_time: 0.010 value: 1
I don’t think they gonna add an option setting for this.
Hi Balazsq
Thanks a lot for the tip.
I’ll try.
Bye
