Extruder motor "released" with CM2784 code. How do I fix this?
A problem with the supply spool caused the filament to stop. This caused the extruder to jam and I received the trouble code CM2784 and said that the extruder motor was “released”. After repairing everything I continue to get the error. What do I have to do to reset the extruder motor?
Factory Reset
I have done a factory reset once with no change. I will try once again just to be sure. Thank you.
I turned it back on again today and now its working. Thanks again.
I think this means it was emergency-stopped, so was purposely shut-off with no way to turn it back on (until reset.) In that case, power-cycle the printer to re-enable it.
