Extruder problem when printing TPU on K2
If you live in a desert you could be fine. I live by the sea, in a woodland, by a stream in England, I might as well be printing Jacque Cousteaus’ aqualung whilst he was testing it.
Are you sure that is a K2 plus extruder. Here is a picture of both my halves.
principle is the same.
I think that I have highjacked the thread in order to get advice on printing TPU. I have a K1C and not a K2. Apologies for the confusion
Whichever the printer I would print a temperature calibration, the temperature window for TPU (well the ones I have used) are quite narrow outside which TPU strings badly.
So invested in a Creality Dryer. Printed TPU perfectly now. Another lesson learned
Once you find a brand of TPU that you find prints perfectly probably best to stick with that brand, they can vary quite a bit.
Thanks. I am using Formfutura’s Flexifil
Try this one on reddit some people use it with suc6 https://www.printables.com/model/1152328-k2-plus-extruder-manual-tensioner
And FWIW, I have a PEI plate with Magigoo glue so I can get the print off!
Why do you need glue? I did when I first started and learned it was due to bed strain gauge and since replacement don’t use it. For TPU,ABS,PA,PLA and PEtg
When printing TPU on a PEI build plate glue is a good idea as a release agent, it sticks so well to PEI that you can destroy the buildplate, the glue saves it from sticking too strongly.
I have a spare build plate I’ll try it with and without tonight I need print some tires
Hi everyone,
I also experienced this issue with TPU on my K2 Plus (filament looped out the side of the extruder mid-print). After testing and digging around, I can confirm this is a known issue related to extruder design and filament path.
Creality has published an official troubleshooting page with clear recommendations: https://wiki.creality.com/en/k2-flagship-series/k2-plus/print-tpu-filament
  • Remove the PTFE tube, insert the TPU directly into the extruder.
  • Drastically reduce retraction (0.2–0.5 mm) and lower speed (20–30 mm/s).
    Use TPU ≥ 90A, avoid softer grades (75A/80A).
    Disable automatic calibration (PA and Flow) which may cause jams during startup.
I came across this video by a YouTuber named Stay Ready To 3D Print who claims he has solved the TPU problem on the K2 Plus by swapping out the spring and a few other mods:
My Secret To Printing TPU on The K2 Plus (100+ hours No Fails)
That’s a pretty interesting video-easily making the spring tension user-adjustable on the extruder is huge!
I really wish there was a repository somewhere listing all the hacks users have come up with to overcome all the issues with the K2+. Not a thread with back-and-forth, but just a chart. It’s hard to keep up with all these fixes!
+1 to a repository of fixes… sadly I’ve needed quite a number of them to date…
@Chris.S_NZ
NICE WORK!!! One stop shopping for many of the issues/fixes on the K2 forum, along with a bunch of bonus info—Thanks!
Its over a year later , and I stumbled across this post! So glad people found the TPU kit we sell so helpful. It really did make printing TPU as easy as PLA. Idk why more brands arent adding tensioner springs to extruders. Tpu does NOT require the same tension as PLA. Oh and turn off retraction guys. rather have a little stringing than failed print. Good Luck ! See you all on the Ytube!
