Falcon 2 22W engraving pass trough (laser is ON all time, on moving too)
Can you help me where the problem could be?
My new Falcon 2 22W also engraves auxiliary lines through the material.
Where can be the problem? I tried it on Lightburn and LaserGRBL too, but but he does it all the time.
Laser dont turn off and on, is all time on, if is moving too, all time…
Same problem here. When powering the machine on, the laser turns on at full power. Laser light turns off after a minute of being idle, but, when I give Frame command, it turns on again at full power.
Any ideas?
This is generaly a bent pin on one of the cables.
Carefully disconnect any cables and check pins to ensure none of them is bent.
Re-insert carefully.
