Falcon 2 40w laser issues
You were completely right - some connectors were bend. Thanks a lot. The Creality support is completely useless - they replied after a week and they’ll send me a new motherboard…
Also, they ignored my repeated request to return the laser…
Anyhow, I am grateful for your advise.
well, I wonder if this could be what is causing my low air alarm faults, I’ll have to hog out the connector a bit and make sure no pins are bent over. under the assumption that the air sensor is in the laser and it’s reading is relayed back to the board on the frame thru this same connector. fingers crossed that this thread is fits my issue as well.
do you know what connector type it is
Ten samý problém CZ.
Bohužel to samé jsem CZ.
